_io_dev_install compile errors
Question asked by Jeff Kadin on Apr 26, 2011
Latest reply on Apr 27, 2011 by Jeff Kadin
I am trying to use an external SPI flash to store my web page data on a TWRMCF52259.
I have the SPI FLASH working using the BSP's spi0  and MQX fopen ("spi0:", NULL)
I can read, write, and erase the flash using this method.
I am trying now to install an io driver so I can layer on part manager and MFS and I am getting an error when I build with the _io_dev_install
This is my code that gets the error:
_mqx_uint _io_webflash_install(
        char_ptr identifier)
_mqx_uint    result;
    result = _io_dev_install(identifier,
        _io_webflash_open,
        _io_webflash_close,
        _io_webflash_read,
        _io_webflash_write,
        _io_webflash_ioctl,
        NULL);
    return result;
This is the Error I am getting, and have not been able to solve it with anything I have tried.
>illegal implicit conversion from '__regabi long (struct mqx_file *, unsigned
>char *, long)' to
>'__regabi long (*)(struct mqx_file *, char *, long)'
Does anyony have any ideas?
Thanks for reading
