Here is the error list.
Error : Unrecognized mnemonic: move.w
MC56F83xx_init.asm line 89 move.w #fmClkDiv,x>FMCLKD
Error : Symbols must start with alphabetic character
MC56F83xx_init.asm line 97 bfclr #$0006,x>PLLCR ; select prescaler
MC56F83xx_init.asm line 98 bfset #$0001,x>PLLCR
MC56F83xx_init.asm line 100 bfset #$0010,x>PLLCR ; power down PLL
MC56F83xx_init.asm line 103 bfset #speedIndex,x>PLLDB ; set speed index
MC56F83xx_init.asm line 106 bfset #$0080,x>PLLCR ; set lock detector on
MC56F83xx_init.asm line 107 bfclr #$0010,x>PLLCR ; power on PLL
MC56F83xx_init.asm line 112 bftsth #$0020,x>PLLSR ; wait for lock
MC56F83xx_init.asm line 116 move.w #$0082,x>PLLCR ; switch system clock to PLL postscalar
MC56F83xx_init.asm line 139 move.w #-1,x0
Error : Unrecognized mnemonic: moveu.w
MC56F83xx_init.asm line 140 moveu.w x0,m01 ; set the m register to linear addressing
MC56F83xx_init.asm line 142 moveu.w hws,la ; clear the hardware stack
MC56F83xx_init.asm line 143 moveu.w hws,la
Error : Unrecognized mnemonic: move.l
MC56F83xx_init.asm line 154 move.l #>>F_Lstack_addr,r0
Error : Unrecognized mnemonic: adda
MC56F83xx_init.asm line 157 adda #1,r0
Error : Unrecognized mnemonic: tfra
MC56F83xx_init.asm line 159 tfra r0,sp ; set stack pointer too
MC56F83xx_init.asm line 160 move.w #0,r1
MC56F83xx_init.asm line 162 move.w r1,xsp) ; put zero at top of stack
MC56F83xx_init.asm line 163 adda #1,sp ; increment stack
MC56F83xx_init.asm line 164 move.w r1,xsp) ; put another zero
MC56F83xx_init.asm line 182 move.w #0,y0 ; pass parameters to main()
MC56F83xx_init.asm line 183 move.w #0,R2
MC56F83xx_init.asm line 184 move.w #0,R3
Error : Unrecognized mnemonic: debughlt
MC56F83xx_init.asm line 200 debughlt ; or simple end of program; halt CPU
DSP56800E_promxram.asm line 51 move.w #F_pROM_to_xRAM,x0 ; optional check
Error : Unrecognized mnemonic: tst.w
DSP56800E_promxram.asm line 52 tst.w x0
DSP56800E_promxram.asm line 75 move.l #>>F_Ldata_size,r2 ; count
DSP56800E_promxram.asm line 76 move.l #>>F_Ldata_ROM_addr,r3 ; src address -- ROM data start
DSP56800E_promxram.asm line 77 move.l #>>F_Ldata_RAM_addr,r1 ; dest address -- RAM data start
DSP56800E_promxram.asm line 80 do r2,>>end_romCopy ; copy for r2 times
DSP56800E_promxram.asm line 81 move.w pr3)+,x0 ; fetch p value at address r3
DSP56800E_promxram.asm line 85 move.w x0,xr1)+ ; stash value at x address r1
DSP56800E_zeroBSS.asm line 43 move.l #>>F_Lbss_size,r2 ; move count
DSP56800E_zeroBSS.asm line 44 move.l #>>F_Lbss_addr,r1 ; start address is BSS start
DSP56800E_zeroBSS.asm line 45 move.w #0,x0 ; zero value
DSP56800E_zeroBSS.asm line 48 do r2,>>end_zeroBSS ; copy for r2 times
DSP56800E_zeroBSS.asm line 50 move.w x0,xr1)+ ; stash value at x address r1
Warning : unsupported option: Enable C++ Exceptions
isr.c line 1 #include "IO_Map.h"
Warning : unsupported option: Enable RTTI
Warning : unsupported option: Enable bool support
Warning : unsupported option: Enable wchar_t Support
Error : unknown assembler instruction mnemonic
(included from:
IO_Map.h:34
isr.c:1)
PE_Types.h line 126 asm { move.w Xaddr),reg }
MC56F834x_vector_isr.asm line 26 debughlt
MC56F834x_vector_isr.asm line 35 debughlt
MC56F834x_vector_isr.asm line 44 debughlt
MC56F834x_vector_isr.asm line 53 debughlt
MC56F834x_vector_isr.asm line 62 debughlt
spi_routines.c line 1 #include "IO_Map.h"
(included from:
IO_Map.h:34
spi_routines.c:1)
fpga_comm.c line 1 /********************************************************************************
(included from:
IO_Map.h:34
fpga_comm.c:12)
xflash_routines.c line 1 //**************************************************************
(included from:
IO_Map.h:34
xflash_routines.c:7)
can_comm.c line 1 /*
(included from:
IO_Map.h:34
can_comm.c:14)
can_comm.c line 470 asm(move.l BL_START_ADDRESS, N);
Error : illegal operand
can_comm.c line 471 asm(jmp (N));
can_routines.c line 1 #include "IO_Map.h"
(included from:
IO_Map.h:34
can_routines.c:1)
init.c line 1 /*
init.c line 1 /*
init.c line 1 /*
init.c line 1 /*
main.c line 1 /*
main.c line 1 /*
main.c line 1 /*
main.c line 1 /*
sram_routines.c line 1 //**************************************************************
(included from:
IO_Map.h:34
sram_routines.c:6)
utils.c line 1 /*
utils.c line 1 /*
utils.c line 1 /*
utils.c line 1 /*
(included from:
IO_Map.h:34
utils.c:13)
match.c line 1 #include <stdlib.h>
menu.c line 1 #include <stdlib.h>
switch.c line 1 //************************************************************
Solved! Go to Solution.
The project had to be converted to a new format. Is that at all consistent with using a re-installed tool on an old project that was problem-free-running before? i need to retract this thread methinks
