I want to learn Freescale MCU programming, which evaluation should I choose to start. I can not spend much on evaluation board. Please help.
You did not specify your CPU requirements. Given that price is a major concern, you might try the i.MX53 Quick Start Board. It's currently priced at $149, and if you need an operating system, you can run Linux or Android on it.
---Tom
