hello, i use coldfire mcu v6 compiler with a mcf51JM64 microcontroller and i want to declare a vector and it dowsn't work, it compile it but when a run the aplication it sees value 0 in vector.
Please help, thanks.
Are you using CodeWarrior? If so, ask your question in the CodeWarrior forum.
Otherwise, WHAT compiler are you using? "coldfire mcu v6 compiler" doesn't narrow it down enough to help.
Tom
