I am using MCF51AC128CLK mcu and I have a very simple task to do.
Generate PWM signal and at the same time trigger ADC converter to make 1 measurement while PWM signal is "high".
Can this be solved using hardware triggers or not?
Can I do this with FTM1 and ADC modules? If yes I would like to ask how?
Florijan
Ok,
my mistake. I will post this message on the other forum.
best regards,
Florijan
Hello Florijan,
Perhaps you will have a better chance of receiving an answer to your query if you post to the correct forum. The 8-bit forum is not appropriate.
Mac
