I'm running successfully the Coldfire-Lite application
and now want to add some hardware I/Os etc.
by using the Processor Expert------
Solved! Go to Solution.
could you please write some details about your use case ? Do you wan to use the ColdFire Lite for web server and and Processor Expert for some input-output?
Would it be a possibility for you to use MQX with Processor Expert instead?
best regards
Petr Hradsky
Processor Expert Support Team
From Service I got this answer:
"Add processor expert to ColdFire_Lite is very, very complicated."
best regards
Petr Hradsky
