Ion Popescu
MCF5225X Tower - serial communication
Discussion created by Ion Popescu on Mar 15, 2011
Latest reply on Mar 20, 2011 by Mark Butcher
I've just started the Tower kit and I am trying to run the "Hello" project from MQX. The problem is that I can connect to tower, I can flash the program, but I get nothing on Terminal window (using a straight cable from my computer to RS232 connector - which is placed on the below board). I'm not sure if everything is set up, because independently on which project I run, I can not see anything in terminal window.
Some help, please ?
Thank you
