CW10 Kinetis inline assembly
NoeSerres
Trying to port a project from IAR to Codewarrior v10 for Kinetis, I have a comilation error when calling inline assembly.
Example: trying to compile     foo = __REV(bar);    /* OK with IAR compiler   */
The error is                                Undefined : "__REV"  /* Error with CW compiler */
What is the correct syntax for calling assembly instructions or functions?
Should I include a header like "intrinsics.h" and where to find it for Kinetis K60?
Is there a document where I could find the list of all existing inline instructions?
Any advice would be appreciated.
admin
Specialist II
If the __REV function is being used for endian translations, the htonl() and htons() could be functionally equivalent (assuming a little-endian host).
