I am new to using MQX and its documentation. The _lwmsgq_receive function in the reference manual, has a LWMSGQ_RECEIVE_BLOCK_ON_EMPTY with an error code of LWMSGQ_EMPTY. However, a block task never returns. How do I check to see if there is an message?
I have been looking at the MQX reference guide, the users guide and the guide. Like I said I am new at this but where is the documentation? I am thinking there should be a documented way to find the number of messages or the status and I have not found it YET. Hope springs eternal!
Solved! Go to Solution.
Hi Barber,
I've taken the default FSLMQX/mqx/examples/lwmsgq project and modified it to operate in several ways by changine #if / #elif statements.
1)_lwmsgq_receive((pointer)server_queue, msg, LWMSGQ_TIMEOUT_FOR, 0, 0); //blocks while waiting for message...default code
2)_lwmsgq_receive((pointer)server_queue, msg, LWMSGQ_RECEIVE_BLOCK_ON_EMPTY, 1, &ticks); //blocks only 1 tick duration waiting for message
3) if (!LWMSGQ_IS_EMPTY(server_queue)){ //checks for message in queue
Server.c snippet:
while (TRUE) {
#if 1 //DES test code
printf("Queue has message....go get it... ");
printf(" %c \n", msg[0]);
_lwmsgq_send((pointer)client_queue, msg, LWMSGQ_SEND_BLOCK_ON_FULL);
else {
printf("\t\t***NO MESSAGE IN QUEUE***\n");
_time_delay_ticks(1); //DES block to give other task(s) chance to run
#elif 0 //DES test code
result = _lwmsgq_receive((pointer)server_queue, msg, LWMSGQ_RECEIVE_BLOCK_ON_EMPTY, 1, &ticks); //blocks only 1 tick duration waiting for message
if(result == MQX_OK){
else if(result == LWMSGQ_TIMEOUT){
printf("LWMSGQ_TIMEOUT\n");
else{
printf("error=0x%08X\n", result);
#else //DES default code
#endif
Client.c snippet:
_time_delay_ticks(5);
//DES _time_delay_ticks(1);
I tried attaching the files but system wasn't letting me do that :smileysad:
Hope this helps.
David
Hi Barber,
Server.c snippet:
while (TRUE) {
else {
else{
#endif
Client.c snippet:
Hope this helps.
David
Thanks for the help. I am still learning where to find documentation on the MQX functions. It appears there a lot of information in the header files that is not included in the MQX manual. I never did find LWMSGQ_IS_EMPTY in the MQX documentation. Is this typical for all the MQX functions or specific to the the light weight message functions?
Again thanks
Hi Barber,
Yes to the question that not every function or macro call is fully documented. The doc's to a good high level of implementation, understanding, and advice for porting but one must roll-up the shirt sleeves and review code to find answers to questions not in the documentation.
I often start by using one of the FSLMQX/mqx/examples projects then look at headers and/or do searches on keywords. That is the path I took for creating the lwmsgq example.
As time passes we/Freescale will keep adding to the documentation to improve. Sorry for any hassles.
David
