I downloaded FSLMQXOS_3_6_2.exe, which is the MQX source. However, I am developing on Linux and doubt that an EXE is the correct way to start. How do I get sources for MQX that work with CW 10.1 running on Linux?
I tried installing the MQX .exe file on a windows machine, and copied it over to the linux machine. But I can't get it to compile using CW 10.1.
So my question is how to get started with MQX running CW10.1 on Linux. Hopefully there is a guide out there somewhere for this.
Thanks.
Solved! Go to Solution.
I had a very similar problem and the answer from support center was:
"CW10.1 does not support MQX 3.6. Please wait until our MQX 3.7 release which is in March 31. This version will be supported in CW10.1."
