I've had the Codewarrior and tower system for only a couple of day, and I'm trying to just get a demo to work.
I was able to build and download to TWR target the Hello demo with only "Please check your JTAG clock speed"
showing up at the start of each debug session, but I wasn't able to step. I could read registers and such, but target wouldn't run.
After a couple of tries, the above is followed with "CCSProtocolPlugin: Failed to continue thread [Invalid parameter]" every time I attempt to connect with the TWR-MPC5125 target board and will not go any farther.
My steps have been:
1) Select "Hello" demo from examples directory (c:\Program Files\Freescale\Freescale MQX 3.6\mqx\examples\hello\cwmpc92
2) Click the "make" button
3) Click the "Debug" button
pop-up: "Connecting [try 1]"
pop-up: "Configuring TAP..."
Second pop-up: "Please check your JTAG clock speed"
4) click "ok" on above
pop-up: "Downloading xxxxxx"
Debug window appears for an instant then goes away
pop-up: "CCSProtocolPlugin : Failed to continue thread [Invalid parameter]
5) click "ok"
<Back at project>
Any suggestions for what I'm missing?
Dave
Working. I completely uninstalled (scrubbed filesystems and registery of everything freescale/codewarrior) and reinstalled. I'm able to run the Demos.
