MSC8156ADS I2CBoot demo
Jim95
Hello, I try to boot on I2C EEPROM, using the I2CBoot demo, but after creatin the .txt and burn it into the EEPROM, when I power off and power on the board it doesn't boot on the loaded program. I followed all the instruction of the text file: file How to.doc. I don't understand why it doesn't work.
Tags (2)
Jim95
I have find the solution, the addresses of __ctr0_start was not good in the SC3850.mmp file. Now it works fine. Thank You.
AndrewinApps
Which version of CodeWarrior are you running?
Regards, -Andrew
Jim95
