I am using SlickEdit Version 15.0.1.3 with the latest hot fixes.
Something I have noticed for a long time, the documentation says that tabs for files with same name but different extension would show only only tab with the full name and the rest with just the extension.
While this works for source code, such as .c and .h, files, it does not appear to work for non-source code files, like .mak and .prm.
I have attached a screen picture to show this.
Solved! Go to Solution.
Hello
Are you sure you are targeting the appropriate forum here?
This forum can help you with questions related to CodeWarrior tool chain.
Slickedit is not a Freescale product. I assume you install a SlickEdit plug in on top of your CodeWarrior installation.
Please check on http://www.slickedit.com/products/slickedit-core. There is a dedicated forum up there.
CrasyCat
Hello
CrasyCat
