Giovanni Parodi
Trying to build -AsRomLib
Discussion created by Giovanni Parodi on Feb 6, 2011
Latest reply on Feb 7, 2011 by Giovanni Parodi
Good morning,
I have a problem related to building a ROM library for a HCS08 device.
I modified a code that worked fine as a complete SW (generating an executable).
Then I commented the
void main()
method and selected the
-AsRomLib
linker option.
Afterwards, I inserted in my code the lines of code:
    #include <startup.h>
    struct _tagStartup _startupData; /* for linker */
Finally, I had to modify the default .prm file specifying the code section that will be used outside of the lib (I had to do this since my lib use the ansi lib and generated many error without this trick).
In the prm I wrote:
ENTRIES
    file1.obj:*
    file2.obj:*
    file3.obj:*
END
However I have a problem: while building the lib I get the message:
Object _Startup not found    Circuito_1_asRomLib        line 0    C/C++ Problem
I tried modifying the ENTRIES adding also the line
    _startupData
but I'm not able to solve this problem.
I tried searching the web and the "HC(S)08/RS08 and HC(S)12 Build Tools Utilities Manual" provided by freescale, but I'm not able to solve this problem.
Is there someone that can help me?
Any idea will be appreciated.
If I forgot to specify some useful info, please le me know.
Giovanni
