I'm trying to automate the build of projects under Codewarrior 10.1.8 (StarCore). I have not been able to find a tcl build command yet, so I'm wondering how I could build a project by any other means or even with TCL, maybe I'm missing something.
The whole process has to be automated for a nightly build system, anything that requires interaction with a GUI is not usable for this task.
My other option seems to be setting up my own Makefiles, especially since the ones generated don't perform a clean properly when called from cmd.exe (I'm stuck with windows (commandline is too long)).
If you have any ideas on how to setup such a system or have at least answers to my questions above, I would be glad to receive your input.
Killian
Solved! Go to Solution.
Hello
As far as I know you should be able to use the option -config "MyConfig" to build the configuration MyConfig.
Here is the help from the ecd binary:
Eclipse Command Line Driver.Usage: -command optionsavailable commands: -help -generateMakefiles [-verbose] [-project path [-config name | -allConfigs]] -build [-verbose] [-cleanAll] [-project path [-config name | -allConfigs] -cleanBuild]
CrasyCat
Hello
There is a tool called ecd that can be used to perform automated build.
Please look at {Install}\SC\Help\PDF\Freescale Eclipse Extensions Guide.pdf, chapter Debugger section Automated Builds for more information.
CrasyCat
This is great! It does pretty much what I want. Do you see any chance of setting the Build Configuration before the call to ecd (other than from the IDE) or as command line parameter?
Killian
Hello
CrasyCat
This is perfect. Thanks a lot for your help.
Killian
