I am using CodeWarrio ver 5.0, build 9061 for S12X with build tool update 5.0.1, build 10038
I put the following in my code:
#pragma DATA_SEG EOLPROGvunsigned short EOLcode;#pragma DATA_SEG DEFAULTextern unsigned short __SEG_END_EOLPROG[];
and then, in my PRM file, in the PLACEMENT section:
EOLPROG INTO NO_INIT 0x7F6C00'G TO 0x7F6FFF'G;
But, the address of __SEG_END_EOLPROG was 0x7F6C02. I was expecting it to be 0x7F7000.
While I can unserstand that "EOLPROG INTO EOLRESERVED" would get that result, here I am directly defining the address range for EOLPROG, so it would be reasonable to expect the address of __SEG_END_EOLPROG would be 0x7F7000.
Any other way to get what I am looking for? (other than defining 2 ranges)
Solved! Go to Solution.
Hello
The linker is always allocating a section at the beginning of the segment where it is placed.
You cannot direct it to allocate the section at the end of a memory area.
See following post for instruction on how to request an extension in the tool chain.
https://community.freescale.com/thread/77166
CrasyCat
Hello
CrasyCat
