I'm getting started. I'm completely new to code warrior. is there any step 1 2 3 to write a good program? which resources do you think is more helpful? reference manule or the MQX?
Solved! Go to Solution.
HI,
Try to read documents listed here Learn to use MQX.
In the instalation path of MQX are a lot of program examples you could examine.
Good luck.
HI,
Good luck.
