I have used pin 47(TMS) for timer output, now I cannot reprogram processor. Is there a way to erase program and start over.
Do you have the serial port hooked up.. The DSP has an internal serial bootloader that works at 115200 N81 Xon/Xoff. Just use hyperterminal and download the .S after the Splash screen apears.
