I have Installed CodeWarrior for MCU v10.1 successfully & then I started installing MQX 3.6.2, its installer did searched for CodeWarrior as usual, but it failed to find it. (Please ref. screenshot attached).
Can anyone guide how I can link MQX with CodeWarrior workbench?
Thanks in advance.
Solved! Go to Solution.
its because MQX 3.6.2 does not support TAD plugin for CodeWarrior for MCU v10.1 yet. It will be enabled in next MQX release.
I am having the same problem.
The only version of CodeWarrior 10 to download is version 10.1. Does this mean I can't do MQX development with CW10.1 and MQX 3.6.2?
