kapil sharma
Problem with first time programming of S9S08SG32
Discussion created by kapil sharma on Dec 22, 2010
Latest reply on Dec 23, 2010 by Daniel Lundin
I am working on controller with part no. - S9S08SG32E1WTL
Below is the SCH as in our board for the controller programming section. We are facing issue with first time programming of the board.
When we use 6-pin connector along with P&E debugger to program the board, for the very first time when we try to program it, it displays “Connect (Reset)” window, which is repeated again and again, and the board doesn’t get programmed. We have seen the reset, it is happening properly.
What could be the reason for same and what can be done to get it right?
Kapil Sharma
Sr.HW Design
+91-9225630924
