Hello all,
I am a new user of coldfire lite. I have a project ready with code warrior V7.2 with processor expert. Now I want to add Ethernet functionality. I have downloaded the coldfire lite stack.
Can anybody guide on the step by step procedure for integrating the coldfire lite stack with the existing code?
Thanks in advance.
Avinash
If you want to use (the official version of) Coldfire Lite, you'll have to step back to Codewarrior 7.1 as CF Lite is not compatible with CW7.2. Of course, compatibility issues can be fixed, which I did. You can find the fixed version here:
http://www.mvdh.be//CF_Lite_32_patched/7.2 REG_ABI 20101024.zip
It contains targets for MCF5223x and MCF52259 cpus and all sample code has been stripped of.
How to merge your code to CF Lite I cannot tell. Depends a lot on how your code has been built up I guess. It may be a better idea to take a look at FNET, which is made to add network connectivity to existing applications. See:
Thanks.
I would like to know the include files & the initialization
Avinash
