I am new to V10 and programming for coldfire. I am runnning special edtion.
Why can I NOT do a simple Open Project. From the menu Project>>Open Project.
It is greyed out.
Thanks in advance.
Hello
Are you looking for a way to add an existing project to your workspace?
If this is what you are looking for you need to use File > Import and then select General > Existing Project into Workspace.
The entry Project > Open Project can only be used for project that are already visible in the Workspace, but have be closed (using Close Project).
CrasyCat
I'll try that. Thanks
