CW 10 Eclipse Interrupt Yellow Underline
emh203
Hello:
In CW10 all of my interrupt routines:
interrupt VectorNumber_Vtpm2ovf void TPM1_Overflow(void)
are all yellow underlined and reports as a syntax error (with a question mark beside it).
The code compiles fine.  I just want to get rid of the marker.
darknight
I have the same problem, if I use vector in prm file only the first line on interrupt is syntax error,
and without use prm file like emh203 the interrupt is underlined with syntax error.
:smileysad:
CarlFST60L
Senior Contributor II
All these years later and it is still not fixed, I just submitted a service request.
robert_t
Same problem, any response?
kef
Specialist I
Interrupt keyword isn't standard. You could use Eclipse friendly #pragma TRAP_PROC to make function returning with RTI instruction. But then you need vectors table.
