Java application for monitoring a Zigbee devices
markez
hi,
It's the first time I use ZB. As part of a project for my University last year,  I want to create a java application for monitoring a sensor data.
I have a coordinator plug into pc via usb and my java application use a java.comm library for communication with ZB coordinator.
I use a MC1322x NSK and I work with Smart Energy profile of Beestack.
I would like to know How can I send a ZLC command for require data from End Device with java?
Can anyone help me, please?
thanks
erooll
Hi Markez,
I recommend to you, use rxtx library; this library is ported to windows and linux instead java.comm that are avaliable to Solaris SPARC, Solaris x86, and Linux x86.
Also could be usefull this api:http: //code.google.com/p/xbee-api/, but was designed to Xbee modules.
