Justin Abraham
MCF52235, Interniche Lite 7, UDP Broadcast
Discussion created by Justin Abraham on Dec 1, 2010
Latest reply on Jan 14, 2011 by TomE
Hi all,
I'm attempting to do a UDP broadcast using my MCF52235EVB. My PC is setup with IP address 100.1.3.186, subnet 255.255.0.0. In the "main.c" file i set my board's IP to 100.1.3.100 and subnet to 255.255.0.0.
I then played around with the "freescale_UDP_client.c" file to send UDP packets to my PC. it works fine if i set my send address to that of my PC. but what i want to do is send packets to any PC with IP 100.1.3.x. To do this i set my send address to 100.1.3.255, but now my PC cannot see the packets.
I ran Wireshark (network monitoring software) and found that my PC can see the packets but keeps asking "who is 100.1.3.255?". So basically my PC thinks that 100.1.3.255 is a specific PC's address and not a broadcast.
What changes to the Interniche code do i have to make to be able to broadcast UDP packets to any PC with address 100.1.3.x?
I have attached both files. Any help or input would be greatly appreciated, thank you.
