Aurelie Mercier
SPI problem on MC9S08DZ128 and iLCD
Discussion created by Aurelie Mercier on Nov 24, 2010
Latest reply on Mar 31, 2011 by bigmac
First of all, please excuse me for my english, this is not my mother tongue...
I have a problem with SPI on MC9S08DZ128. I would like to make it communicating with an iLCD. Here are its datasheets :
http://www.demmel.com/download/ilcd/spi_appnote.pdf
http://www.demmel.com/download/ilcd/ilcd-color-commands.pdf
I am able to write to the iLCD and use the commands I want. But I can't read from the iLCD. For example, it should send 0x06 as an ACK for each command....
I have noticed that on the appnote, the MOSI is at low level in idle state, but in my case it is high in idle state... what could be the reason ?
I have tried to send a "get data size to read command" but when there should be something on MISO, there isn't anything. The only answer I get is a byte that seems to be 0x01 every time I send 0xAA (this is the start of each command) but the MCU isn't able to read it.
What should I do please ??
Thank you in advance for your help.
