I have developed a C project using Processor Expert and now I would like to copy this project. (I have the same processor with the mostly the same functionality on two different boards). I tried copying the folder and renaming some files, but the PE settings did not get transfered. Is there a tool to handle moving the PE settings?
Thank you,
Randy
Solved! Go to Solution.
I am guessing that you are using CodeWarrior Classic, because you have not mentioned this information in your post.
I think that the easiest way will be the following (this steps also match for renaming a project without point 4):
1- Create new PE Project with MCU that you use
2 - Using “Import…” menu command import all PE settings from origin project (import menu command is available in pop-up menu of "Project Panel" window by clicking into white space)
3 - Copy Events.c, Events.h, and main module from origin project into new one (eventually also user modules)
4 - Set PE components according to another PCB
best regards
Vojtech Filip
Processor Expert Support Team
best regards
Vojtech Filip
