I need my pre processor to notify me of various things throughout my code after incremental MQX updates To do this I check MQX_VERSION using the preprocessor. However, I just updated to 3.6.2 and the version is defined as 360. Is there a reason for this? How else can the pre processor notify me of MQX incremental updates? i.e.
#if MQX_VERSION != 362
#warning MQX has been updated, you need to bla bla bla
#endif
Carl.
Solved! Go to Solution.
that is the bug in the 3.6.2 release. The version numbers will be incremented properly in further releases.
PetrL
PetrL
