Forcing 10 Mbps Ethernet Connection
Question asked by Rafael Dazcal on Nov 9, 2010
Latest reply on Nov 22, 2010 by Rafael Dazcal
Greetings,
Is there a parameter where I can force RTCS to establish a 10 Mbps (10Base-T) even if the network supports 100 Mbps connections (100Base-TX)?
Also, if I do so, are there 100Base-TX only networks? I suppose a 10Base-T should work in any network, correct?
I need this in order to save power in my end-device
Thank you
