YANG TIANXI
How to implement  4byte divide 2byte divide fasty?
Discussion created by YANG TIANXI on Nov 9, 2010
Latest reply on Nov 12, 2010 by Oliver Betz
in my application,   4 bytes / 2 byte is need  as following,
dword     a;               /*   a  is type of unsigned long , 4 bytes  */
word       b;               /*   b is type of  unsigned integer, 2 bytes  */
word      c;
c =  a /b;
if I code it  in  C ,   c =a /b take more than 200 CPU cycles, it is too long for my application, so  i consider implimenting it  in assembly  language,  my CPU is HCS08, and only have one division instruction:
    DIV                             /*    A<--(H:A) /(X);  H<-- remainder 6 CPU cycles , 16-bit by 8 bit divide instructions  */
how to implement  a  4 bytes  variable divide 2 bytes variable  in assembly  fastly?   thanks .
