Lukas Capek
Array structur and extern declaration
Discussion created by Lukas Capek on Nov 6, 2010
Latest reply on Nov 8, 2010 by Daniel Lundin
Hi.
I have problem with extern declarition array off structure. I use S08JM.
In main.c I have declaration:
typedef struct {
    u8t   battery;
    u8t   sensor_connect;
    s16t  temperature;
    u16t  humidity;
} SENSORS_DATA_STRUCT;
SENSORS_DATA_STRUCT    Sensors_data[10];
in second file.c I want to use extern declaration:
extern struct SENSORS_DATA_STRUCT Sensors_data[10];
but I can´t compile, extern declaration structure works, but array structure doesn´t work,
Do you know where is problen? thank you
