Dear everyone,
I am new to MPC55xx linker and .map file area.
If there is any single document or single place (except Code warrior help) where I can find explanation about the default generated .lcf file, that would be a great help to me.
thank you
nandu
Solved! Go to Solution.
Hi ndk,
There is the latest CW for Power Architecture® Processors Build Tools Reference available on the Freescale web:
The same .pdf document should be available in the CodeWarrior Help\Pdf directory (<CW for MPC55xx and MPC56xx 2.x>\Help\PDF\Power Architecture Build Tools Reference.pdf)
See the Linker section for more information.
Stanish
Hi ndk,
Stanish
Hi Stanish,
Thanks a lot for the information.
