Apter Slava
USB speed on MCF51JM128
Discussion created by Apter Slava on Oct 11, 2010
Latest reply on Oct 14, 2010 by TomE
Hi guys.
I am using in my system micro MCF51JM128. According the datasheets, if i configure micro to work as a device on
Full-speed( I mean 12 MB/sec or 1.5 MByte/sec), this is a speed that i expect from USB bus in this case. But actually, i get only 550 KByte/sec speed and this is not enough. I need at least 1 MByte/sec. I am using by ALL free endpoints for output.I have only one endpoint for input,so the solution to change Input endpoint to be altered on-the-go(OTG) can improve the throughput, but it is not a good enough solution,because still i can not get 1 MByte/sec.
Anyone faced this problem before?How to solve it, if u faced this problem?
Thank,you Slava.
P.S. I am using USB driver that i found in Freescale application CAN_USB bridge.Maybe the problem is in this driver.
