Can anyone direct me to some application notes regarding SPI module communication with an external EEPROM on an 8 bit MCU (MC68HC908QC8), and register setup and initialization examples would be much appreciated.
HLIU
Solved! Go to Solution.
The attached assembly code files are intended to support a 512kbit EEPROM device when used within a relocatable project. You would need to modify to suit your specific needs.
Mac
Is anyone can supply examples in assembly code format?
HLIU
Mac
Thanks all. After I study the sample program and relating information, I know what to do.
Thanks again.
HLIU
