I run in Lockstep mode. And as soon as a "stmw" instruction is executed, I get a reset and end up in "SAFE" state.
The RGM has FL_ECC_RCC bit set.
Anything I do wrong in the setup ?
Solved! Go to Solution.
Ok, replying myself :-P
After initializing all r0..r31 with an arbitrary value, the "stmw" works.
