Paul Sweezie
View Registers window not displaying correct data
Discussion created by Paul Sweezie on Sep 3, 2010
Latest reply on Sep 7, 2010 by Paul Sweezie
This is most often the case though sometimes it will display the correct values if I open the window after a breakpoint has been reached and occasionally a previously open view registers window will be updated at a breakpoint as expected.  In this last situation the number is displayed in red as expected.  If I view memory I see the correct values and if I view register details the values are incorrect.
This is version 7.2.1 build 100416 for Coldfire on a MCF5329 via a P&E USB multilink.
This behaviour is different than I experienced with V6.3 for Coldfire and an Abatron BDI2000 connected via Ethernet.
Any suggestions on how to get the register window updating would be greatly appreciated.
Thanks.
