Hi to all,
Looking into RTSHC08.c I've found:
void _ICMP(int j, ...) {
/* DESC: 16 bit compare i <rel> j
IN: X:A i, TOS j
OUT:
WRITTEN: A,H,X */
asm {
CPX j:0
BNE _ICMP_0
CMP j:1
BEQ _ICMP_0
CLRA
BCS _ICMP_1
LDA #2
_ICMP_1: ;
CMP #1
_ICMP_0: ; // flags are set for i - j
_PUL_RA
AIS #2 ; // free pushed parameter
JMP 0,X ! {HX+SR}, {HX+A}
What is TOS? It is very popular in that file, but no documentation on it. Is it a command? what does it mean (transfer on stack?)?
Solved! Go to Solution.
TOS (in this context) usually stands for Top Of Stack.
