copying code from ROM to RAM on startup on MPC56xx
AhmadNasser
I am using the MPC5645S. I have some files that need to be located in flash but copied to RAM on startup. The startup code performs the copy by parsing a table __rom_copy_info:
__rom_copy_info *dci;
    __bss_init_info *bii;
     /* Copy from ROM to RAM: */
    dci = _rom_copy_info;
    while (1) {
        if (dci->rom == 0 && dci->addr == 0 && dci->size == 0) break;
         __copy_rom_section(dci->addr, dci->rom, dci->size);
         dci++;
My question is how to tell the linker to specify that certain segments/files need to be located in that table so that the code can be copied to RAM on startup?
stanish
I'd suggest you to see the thread below:
https://community.freescale.com/thread/66070
Stanish
MPC5646
Hi Ahmed,
I am using the MPC5646C target and I have got your problem, can you tell me how you solved it.
