Hello everybody
I have a question related to how to manage a task that I think is quite easy for expert in MCU's programming but about which I have some doubts.
I'm programming a device HCS08 and I have to store a big amount of data (mainly log related) in non volatile memory (about 350 byte).
Part of this data should be updated each time I restart my board, but retained when the board is shutted down.
In order to avoid using RAM as a temporary storage for data I was thinking about using two page of Flash and using them as a ping pong buffer.
However I don't know if this is the better way or if I missing a better approach.
Can you provide a a feedback about my idea? Is there some example about this topic?
If this is a stupid question, please be patient, I'm a newbie!
You're looking for "EEPROM Emulation" Do a quick search and see if that can answer some of your questions.
AN3824 might help as well (emulation on an HCS08 MCU) http://cache.freescale.com/files/microcontrollers/doc/app_note/AN3824.pdf?fsrch=1&sr=3
