Hello
I have a little problem with targert DAMOEM, it's used MCF51EM256 microcontroller, I'm trying to programmer with the example Freescale give, all go so fine I programmed, but when I want to run the example the targert not show nothing, I think that it could be the clock configurated, but I don't know I try too the MCU show me something in Hyperterminal but I tasted the signals and show so fine in oscilocopy, but in the hyperterminal don't show nothing, Somebody could help me with this problem?...
Thaks
Andrxs,
If you could provide a bit more detail, then I'm sure others on the forum could help a bit.
If you could provide the specific demo and status of any LEDs etc on your board. Also, which devtool you are using etc...
Hope this helps
JWW
