using CW10 on win7 64 bit:
I have made a new project and added my assembly only code (JM60).
it compiles with the error:
make: *** No rule to make target `default.obj', needed by `my code filename.obj.s19'.
I have the latest CW version.
how do I fix this?
Solved! Go to Solution.
That message "no rule to make target" is an indication that the make file is not up-to-date.
Try to do a 'clean' (context menu on the project, or Project > Clean) to have the make file re-generated.
That should solve it.
BK
BK
Can you try to create a "default" project first? and compile?
After that, you could add your files (or asseply code) to see if you still have error.
