There is a bug in MQX3.6 MFS's IO_IOCTL_FIND_FIRST_FILE (MFS_Find_first_file) function.
If you use search attribute MFS_SEARCH_NORMAL it finds no files. This worked OK in 3.3, but appears to have been broken in 3.4.
The problem is in the MFS_Attribute_match() function in mfs_parse.c not handling MFS_SEARCH_NORMAL. Here is a patch that corrects the problem (and properly handles MFS_ATTR_SYSTEM_FILE).
If you use the shell "dir" command you will also want to patch sh_dir.c to change the default search attribute from "m*" to "m". so that files with the archive bit set will also be displayed. This broke with the 3.4 changes to mfs_parse.c.
--Mark
-----8<----------
*** mfs_parse.c 2010/07/13 18:01:07 1.1
--- mfs_parse.c 2010/07/13 19:41:09 1.2
*** 620,642 ****
else
/* if checked file is hidden, and have not selected hidden in wanted mask,
return FALSE otherwise check all others parameters */
if ((dattr & MFS_ATTR_HIDDEN_FILE) && !(wattr & MFS_ATTR_HIDDEN_FILE))
match = FALSE;
else
! if ( dattr & wattr )
match = TRUE;
else
match = FALSE;
--- 620,648 ----
else
match = FALSE;
+ /* same for system files */
+ else if ((dattr & MFS_ATTR_SYSTEM_FILE) && !(wattr & MFS_ATTR_SYSTEM_FILE))
+ match = FALSE;
else
! /* MFS_SEARCH_NORMAL returns all non-hidden, non-system files */
! if (wattr == MFS_SEARCH_NORMAL || (dattr & wattr) )
match = TRUE;
else
match = FALSE;
-----8<----------
*** sh_dir.c 2010/07/13 18:36:48 1.1
--- sh_dir.c 2010/07/13 19:48:18 1.2
*** 68,88 ****
print_usage = Shell_check_help_request(argc, argv, &shorthelp );
if (!print_usage) {
if (argc > 3) {
printf("Error, invalid number of parameters\n");
return_code = SHELL_EXIT_ERROR;
print_usage=TRUE;
} else {
path_ptr ="*.*";
! mode_ptr = "m*";
if (argc >= 2) {
path_ptr = argv[1];
if (argc== 3) {
mode_ptr = argv[2];
fs_ptr = Shell_get_current_filesystem(argv);
/* check if filesystem is mounted */
if (fs_ptr == NULL) {
--- 68,88 ----
if (!print_usage) {
if (argc > 3) {
print_usage=TRUE;
} else {
path_ptr ="*.*";
! mode_ptr = "m";
if (argc >= 2) {
path_ptr = argv[1];
if (argc== 3) {
mode_ptr = argv[2];
-----8<----------
Hi MarkA,
thank you for reporting this bug. We will check your implementation and inlcude fix in the next MQX release.
PetrL
