Is it possible to reprogram the DDR controller on PowerQUICC III more than once after power-up? Our system uses two bootROM (once factory installed, one field-upgradable) and the DDR is programmed in both (not necessarily with the same settings). Is there a different program sequence needed the second time though? Thanks!
