sqrt causing lockup  (NOT a float/linker issue)
Question asked by Sander Van Twisk on Jul 9, 2010
Latest reply on Jul 9, 2010 by bigmac
I've been using sqrt for a while without any issue.
Added a loop to run this function many times to average many ADC samples.
It runs fine then on the 5th time locks up on the second STA here:
STA      Kexp:1
PULA
ADC      #(D_EXPHI)
STA      Kexp:0
; // { exp done }
My code is:
void ADC(void) {  float Fresult;  float PFResult;  float Result_a;  float Result_b;  float temp;  float Result_c;   /*  take 4 ADC readings: VOLT, CURR, FREQ and PF  */  Fresult = (float)FREQ;  PFResult = (float)PF;  Result_a = (VOLT*VOLT)/(CURR*CURR);  temp = sqrt(Fresult);  Result_b = PFResult/(temp*Fresult);                 Result_c = Result_a*Result_b*4096;  adcval = (int)Result_c;  return;}//ADC
Hangs up on the "temp" variable. Only on the 5th time through this code.
The only difference is a counter goes from 4 to 5 for this cycle, but I don't see how that'd make a difference.
What's happening here?
Many thanks!
