Watch Points in Assembly for CW v6.3
admin
Specialist II
Is is possible to set watch points in the CW debugger when coding entirely in assembly as I am able to when coding in C?
CrasyCat
Specialist III
Hello
You can surely put a watchpoint on a memory range inside of the Memory window.
This should not be a problem.
Assembler is not a structured language, so there is no real size associated with a data label.
If you intend to set a watchpoint on a  label in the Data window check the start address and size associated with the watchpoint to make sure it maps what you intend to trigger.
CrasyCat
CrasyCat
Specialist III
Hello
CrasyCat
admin
Specialist II
Thanks for the input. I see it now.
