Daniel Lundin
S08/S12 register maps for the C language
Discussion created by Daniel Lundin on Jun 9, 2010
Latest reply on Jun 14, 2010 by kef
My requirements for a project are:
- I want to use the C language. This is a fairly common programming language defined in ISO 9899:1990.
- I need a register map of all MCU registers for HCS08DZ and HCS12C.
Are there any such register maps available anywhere? As the code needs to in the C language, so the register maps supplied with Codewarrior cannot be used. Does anyone know if any other compiler vendor (Cosmic, IAR etc) are using the C language for register maps in their S08/S12 ports?
