reading MQXMFSUG.pdf I see this comment:
#define MFSCFG_MINIMUM_FOOTPRINT 1
— Set to one to build MFS for small-memory devices, zero otherwise.
In my application I need saving and loading data on a mass storage device but now in the market there are pen drive up 16 GB. When can I use MFSCFG_MINIMUM_FOOTPRINT? Can I use for every pen drive #define FSCFG_MINIMUM_FOOTPRINT 0 ?
Thanks.
Solved! Go to Solution.
The expression "small-memory devices" means Freescale device you are developing your application on, with MQX support.
Thanks for the advice ... I'm sorry for the misunderstanding !!
