How can I use the serial-over-USB feature on TWR-5225x?
Question asked by Sven Kopacz on Apr 30, 2010
Latest reply on May 3, 2010 by Sven Kopacz
Hi all,
I have a 5225x Tower sitting here and I found in the docs that I can route the UART0 to the OSBDM. I assume that the OSBDM will then transport the serial communication over the USB interface (much like the virtual serial port in the P&E interface).
However I cant find any documentation on how to actually use this.
Is there a driver available to make that serial-over-usb port visible on the PC as a regular serial interface so that I can just launch a terminal program?
Or is there some proprietary client available like the PE Terminal?
It would be great if someone could point me to what I probably overlooked, because that would save me from soldering something to hook up the PC to that 10-pin header on the dev board.
 Sven
