What's included with the board purchase? Do I get USB Tap and limited edition of code warrior? Am I able to open box and do some programming?
Thanks in advance.
Solved! Go to Solution.
The list of deliverables include:
1. USB TAP
2. Limited edition Codewarrior
3. BSP CD for the P2020 RDB
4. The board comes with U-boot preinstalled.
You can load the linux image thru USB, NOR, NAND or NFS.
Yes you can do some programming out of box.
1. USB TAP
Thank you very much.
