Jonathan Griffitts
toupper() and tolower() swapped?
Discussion created by Jonathan Griffitts on Apr 21, 2010
Latest reply on Aug 28, 2011 by Marc Vandenhende
Hi, all!  Using CodeWarrior special edition 7.2 for ColdFire.  I find that the toupper() and tolower() macros are totally broken!
This sample code:
static void Temp(void) {    printf("\n toupper  a A 2 \\r = %c %c %c 0x%02x\n",    toupper('a'), toupper('A'), toupper('2'), toupper('\r'));    printf(" tolower  a A 2 \\r = %c %c %c 0x%02x\n",    tolower('a'), tolower('A'), tolower('2'), tolower('\r'));    printf(" isupper  a A 2 \\r = %d %d %d %d\n",    isupper('a'), isupper('A'), isupper('2'), isupper('\r'));    printf(" islower  a A 2 \\r = %d %d %d %d\n",    islower('a'), islower('A'), islower('2'), islower('\r'));}
gives this output:
 toupper  a A 2 \r = a a 2 0x0d tolower  a A 2 \r = A A 2 0x0d isupper  a A 2 \r = 0 1 0 0 islower  a A 2 \r = 2 0 0 0
As you see, toupper() and tolower() functions are swapped.  isupper() and islower() work correctly.
The fix looks to be in file ColdFire_Support\ewl\EWL_C\include\cctype
Swap the macro definitions in lines 70 and 71 as per this diff:
70,71c70,71<  _EWL_INLINE int _EWL_CDECL tolower(int c) _EWL_CANT_THROW { return islower(c) ? c - ('a' - 'A') : c; }<  _EWL_INLINE int _EWL_CDECL toupper(int c) _EWL_CANT_THROW { return isupper(c) ? c + ('a' - 'A') : c; }--->  _EWL_INLINE int _EWL_CDECL tolower(int c) _EWL_CANT_THROW { return isupper(c) ? c + ('a' - 'A') : c; }>  _EWL_INLINE int _EWL_CDECL toupper(int c) _EWL_CANT_THROW { return islower(c) ? c - ('a' - 'A') : c; }
